View unanswered posts | View active topics It is currently Thu Apr 24, 2014 1:28 am
This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 botas Fox Forma F3 !!!!! VENDIDAS !!!!!
Author Message
User avatar
Post botas Fox Forma F3 !!!!! VENDIDAS !!!!!
Vendidas!! ahí sigue el esqueleto!
Como va todo Touaregs? Agradeciendo de antemano a los webmasters q hacen posible el foro y este apartado.
Me llegaron las botas Fox F3, sin embargo me quedaron justas: son del 7-7.5 mexicano. Pido $2800
Cel. 04455-2921-8619
aqui las describen:
These are a new set of Fox Forma Pro F3 Motocross / Dirtbike boots. These boots were built for and by Fox for James "bubba" Stewart and are an extremely comfy set of boots!
Upper/Liner
New premium quality leather wraps around the entire foot and ankle section providing a more feel and comfort and less break in time
3D molded chassis molds precisely to match the curves of your foot
Lower profile toe box makes it easier to shift
Multi-density shin guards and calf guards were researched and developed for maximum flexibility and comfort
New Improved Extreme seal top gasket provides an even closer secure/comfortable seal around leg to keep debris out of boots
Internal molded padding wraps around the inside calf support for extra impact absorption
Lateral internal support is flexible yet secure to give you the extra confidence out on the track
Fold over burn guard
In-molded strap receivers
Soft touch aluminum buckles now have a new shape making them more secure
Buckle bases pivot on their axis allowing perfect alignment between buckle and strap
The soft, grippy rubber insert on the buckle makes for a more comfortable use in any condition, wet or dry, hot or cold
New styling accents (detailed stitching and polished plastic) really set off the new look for the new and improved F3
Sole/Footbed:
New for the F3 outsole is an improved compound for increased durability. The tread design is inspired by the highly successful herringbone design, originated on the Fox Forma Pro.
Cushioning/shock absorbing midsole with new compression molded EVA outsole insert on the inside of the foot reduces large shock and vibration, lessening fatigue to the ankle, knee and back
Outsole design
Seamless interior...
... En otras palabras, dice que son la onda!!
aqui las describen:
Upper/Liner
Sole/Footbed:
Outsole design
_________________
trust me I'm a Doctor
ARTICULO VENDIDO
Sat Oct 03, 2009 10:10 am
Profile
User avatar
Post Re: botas Fox Forma F3
eemmm si las fotos verdad?? emm claro!
Probé la bota izquierda en la Xtz y sin broncas con el pedal de cambios.
De cualquier manera están nuevecitas 0 rasponcitos 0 impacto en la suela.
Algo k me llamó la atención es que la bota tiene como un disipador de calor, por si se queda el motor caliente pegado a la bota en un accidente, y además presumen d que tiene buena ventilación.
Animense!
_________________
Sat Oct 03, 2009 10:27 am
Profile
Animense!
_________________
KLR 650
KLR 650
KLR 650
KLR 650
KLR 650
KLR 650
Sat Oct 03, 2009 8:33 pm
Profile
Alex, Pos a donde las puedo ver y probar
_________________
KLR 650
KLR 650
KLR 650
KLR 650
KLR 650
KLR 650
Sat Oct 03, 2009 8:35 pm
Profile
User avatar
MP enviado
_________________
Sat Oct 03, 2009 11:08 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by STSoftware.
